TwinTurbo.NET: Nissan 300ZX forum - I use PB plaster and a torch
aliaZ
on June 07, 2013 at 7:16 AM
The bolts may get stuck from crud between the caps and bolts
posted by ZXoltan
on June 06, 2013 at 07:18 PM
gently heat the caps with a torch, which causes the aluminum to expand, which loosens the grip on the bolt. spray some PB blaster in there and work the bolt out
cam cap question
1995z32tt
14:49:15 06/06/13
ZXoltan
19:18:13 06/06/13
I use PB plaster and a torch -
aliaZ
07:16:57 06/07/13
Good call on the torch. Need to get one
ZXoltan
09:22:31 06/07/13
found the solution
1995z32tt
13:02:04 06/07/13
found the solution
1995z32tt
13:31:38 06/07/13
